Yocto Layers¶
The meta-cassini
repository provides three layers compatible with the Yocto
Project, in the following sub-directories:
meta-cassini-bsp
A Yocto layer which holds board-specific recipes or append files that either:
will not be upstreamed (Cassini specific modifications)
have not been upstreamed yet
meta-cassini-distro
A Yocto distribution layer providing top-level and general policies for the Cassini distribution images.
meta-cassini-tests
A Yocto software layer with recipes that include run-time tests to validate Cassini functionalities.
Layer Dependency Overview¶
The following diagram illustrates the layers which are integrated by the
Cassini project, which are further expanded on below.
The layer revisions are related to the Cassini v0.9.0
release.
Cassini distribution depends on the following layer dependency sources:
URL: https://git.yoctoproject.org/git/poky layers: meta, meta-poky branch: kirkstone revision: 453be4d258f71855205f45599eea04589eb4a369 URL: https://git.openembedded.org/meta-openembedded layers: meta-filesystems, meta-networking, meta-oe, meta-python branch: kirkstone revision: 166ef8dbb14ad98b2094a77fcf352f6c63d5abf2 URL: https://git.yoctoproject.org/git/meta-virtualization layer: meta-virtualization branch: kirkstone revision: 2fae71cdf0e8c6f398f51219bdf31eac76c662ec URL: https://git.yoctoproject.org/git/meta-security layers: meta-parsec branch: kirkstone revision: c79262a30bd385f5dbb009ef8704a1a01644528e
An additional layer dependency source is conditionally required, depending on
the specific Cassini distribution image being built. This layer dependency
source is the meta-arm
repository, which provides three Yocto layers:
URL: https://git.yoctoproject.org/git/meta-arm layers: meta-arm, meta-arm-bsp, meta-arm-toolchain branch: kirkstone revision: fc09cc0e8db287600625e64905170a6de24f2686
The layers required from meta-arm
depend on the Cassini distribution image:
Cassini SDK distribution images require
meta-arm
andmeta-arm-toolchain
, as thegator-daemon
package is installed on the rootfs.A Cassini distribution image built for the N1SDP hardware target platform requires
meta-arm
,meta-arm-bsp
, andmeta-arm-toolchain
These layers are described as follows:
meta-arm
URL: https://git.yoctoproject.org/cgit/cgit.cgi/meta-arm/tree/meta-arm.
Clean separation between Firmware and OS.
The canonical source for SystemReady firmware.
meta-arm-bsp
URL: https://git.yoctoproject.org/cgit/cgit.cgi/meta-arm/tree/meta-arm-bsp.
Board specific components for Arm target platforms.
meta-arm-toolchain
URL: https://git.yoctoproject.org/meta-arm/tree/meta-arm-toolchain.
Provides toolchain for Arm target platforms
