Security Hardening
Cassini distribution images can be hardened to reduce potential sources or attack vectors of security vulnerabilities. Cassini security hardening modifies the distribution to:
  • Force password update for each user account after first logging in. An empty and expired password is set for each user account by default.
  • Enhance the kernel security, kernel configuration is extended with the security.scc in KERNEL_FEATURES.
  • Enable the ‘Secure Computing Mode’ (seccomp) Linux kernel feature by appending seccomp to DISTRO_FEATURES.
  • Ensure that all available packages from meta-openembedded and poky layers are configured with: --with-libcap[-ng].
  • Remove debug-tweaks from IMAGE_FEATURES.
  • Disable all login access to the root account.
    Note
    When cassini-test distro feature is enabled then root login is enabled. Currently, running inline tests in LAVA require login as root to run transfer-overlay commands.
  • Sets the umask to 0027 (which translates permissions as 640 for files and 750 for directories).
Security hardening is not enabled by default, see Security Hardening for details on including the security hardening on the Cassini distribution image.
Note
Cassini security hardening does not reduce the scope of the Run-Time Integration Tests.
